DigitalReadTask get -200089
Hallo ,
I am trying to use the following code of vb.net to read the channel of a PCI-NI6509. and i get the following error: Taskname specified confilicts with an existing task name status code:-200089
Is my code correct? i did close the channel everytime after i read .
Public Class NI_DIO
    Public Function ReadChannel(ByVal Channel As Integer) As UInt32
        Dim ReadTask As Task = New Task( "DigitalReadTask" )
        Dim xData As UInt32
        Try
            Dim P As String = "Dev1/port" & (4 * Channel) & "_32"
            ReadTask.DIChannels.CreateChannel(P, "port0", ChannelLineGrouping.OneChannelForAllLines)
            Dim reader As DigitalSingleChannelReader = New DigitalSingleChannelReader(ReadTask.Stream)
            xData = reader.ReadSingleSamplePortUInt32()
            ReadTask.Dispose()
        Catch ex As DaqException
        Finally
            ReadTask.Dispose()
        End Try
        Return xData
    End Function
End Class
Message Edited by birders on 03-10-2009 11:45 AM
(3,625 Views)
hello birders,
does this error occur every time you start your program?
may it be, that you have concfigured a task with the same name in Measurement and Automation Explorer?
kind regards,
Robert H
NI germany
(3,596 Views)
