DigitalChangeDetection not raised
I'm trying to developp an application which uses the DAQmx 8.8 library with C#.
I have a NI PC-6514 card emulated on my PC. I just want to be able to detect a change of state in one of the Digital input lines of my card.
There is my code (inspired from the sample delivered with DAQmx) :
In the Load event of my windows form I create the task :
      m_nitkTask = new Task("TestTask");
      m_nitkTask.DIChannels.CreateChannel("Dev1/port0/line3", "TestDigital",
        ChannelLineGrouping.OneChannelForAllLines);
      m_nitkTask.Control(TaskAction.Verify);
      m_nitkTask.Timing.ConfigureChangeDetection(
        m_nitkTask.DIChannels[0].PhysicalName,
        SampleQuantityMode.ContinuousSamples, 1000);
      m_nitkTask.DigitalChangeDetection +=
        new DigitalChangeDetectionEventHandler(m_nitkTask_DigitalChangeDetection);
      m_nitkTask.SynchronizeCallbacks = true;
In the click event of a start button I start teh task :
      m_nitkTask.Start();
      m_cmdStart.Enabled = false;
      m_cmdStop .Enabled = true;
I can wait as long as I want no event is raised (m_nitkTask_DigitalChangeDetection is never called) ... I tried also with the sample and no event is raised in the sample.
Does anyone have any idea what is the problem ?
Thank you in advance for your answers
(4,034 Views)
Accepted by topic author Gasser
Hi, the PCI-6514 is simulated, you said. So there is no possibility to receive a digital change detection event !
This absolutely requires the real Hardware.
regards
Marco Brauner NIG
(4,015 Views)
Hello Hans,
thank you for your answer, you're right man !
It works prefectly with the real device (I use remote debugging to run my app on the test machine)
Greetings
J-D Gasser
(4,004 Views)
