CreateVoltageRmsChannel
I am using the CreateVoltageRmsChannel method to measure a RMS voltage on a usb-6343 analog channel (differential 6/14).  When this code executes, I receive the following error:
     Error -200341
     "Selected physical channel does not support the measurement type required by the virtual channel you are creating"
Here is the line of code (VB .NET) that generates the error:
     myTask.AIChannels.CreateVoltageRmsChannel("Dev1/ai6", "ai6", AITerminalConfiguration.Differential, -10, 10, AIVoltageAcrmsUnits.Volts)
I have tried other channels, but I get the same results.  Is RMS voltage measurement not supported by this device?  Any ideas?
Thanks.
(3,451 Views)
Hi parksma,
The CreateVoltageRmsChannel method only works with NI ELVIS. To get an RMS measurement with your hardware, create a regular voltage task using CreateVoltageChannel, take the output from this task and run it through an RMS function.
Steven K.
Steven K.
Software Engineer
(3,435 Views)
Thank you for the response... that was what I was planning to do if I could not figure it out.
(3,430 Views)
