Create AxisDateTime at runtime
I am trying to create following code at runtime after i deleted the old axis.
Snippet
<ni:AxisDateTime x:Name="xAxis" Orientation="Horizontal" Adjuster="ContinuousChart" Range="00:00:00, 00:00:20">
    <ni:AxisDateTime.MajorDivisions>
        <ni:RangeLabeledDivisions LabelPresenter="mm:ss" />
    </ni:AxisDateTime.MajorDivisions>
</ni:AxisDateTime>
 So far i tried like this
Snippet
AxisDateTime newAxis = new AxisDateTime();
newAxis.Orientation = Orientation.Horizontal;
newAxis.Adjuster = RangeAdjuster.ContinuousChart;
newAxis.MajorDivisions.LabelPresenter = "mm:ss";
 The problem lies with setting the LabelPresenter. I got no clue how to set it.
Greetings
rizardus
(3,111 Views)
Accepted by topic author rizardus
LabelPresenter="mm:ss" works in XAML because it uses a type converter to convert the string value to a ValuePresenter. In this case, the result will be a GeneralValueFormatter with the specified format string, which you can construct in code:
newAxis.MajorDivisions = new RangeLabeledDivisions { LabelPresenter = new GeneralValueFormatter("mm:ss") };
(Note that the default value for MajorDivisions is a frozen object, so you need to create a new instance once to customize its properties.)
~ Paul H
(3,075 Views)
Thank you very much.
(3,071 Views)
