Continue from maximum xAxis value
can somebody please help me with the following WavefromGraph-problem:
I have a WaveformGraph with one XAxis. Attached to this graph there are many plots each plot have its very own YAxis but are sharing one and the same XAxis (the default one of the graph).
I set the default increment to 0.5 seconds each time a value is appended using PlotYAppend(double data). So far so good, here comes the problem I am not able to solve, this drives me mad:
I'm adding, for example, three plots and updating values on these calling PlotYAppend() .... and finish plotting after, let's say, 5 seconds. Then I need to add two new plots which append data by using PlotYAppend() but for this two plots I want them to start plotting where the last (maximum) plot I plotted before has ended (here in this example: start from second 5). Although all the plots are sharing the same XAxis all plots start from second 0.
How can I achieve the above mentioned behaviour?
Message 1 of 8
(4,678 Views)
Hello -
One thing that may work depending upon your application would be to use PlotY instead of PlotYAppend for your first plotting operation per plot.  This way, you can use the overload that includes an offset - allowing you to determine where plotting begins from.
NickB
Message 2 of 8
(4,654 Views)
Hello nickb,
thanks for your suggestion, this however doesn't work since PlotY removes all previous points/history of the plot. What I need is actually something that is able to surpress line interploation between two specific points, say:
point(0,0) -> point(100,10) => Draw no line between, i.e. do not interpolate between these two points.
Message 3 of 8
(4,644 Views)
I attached a picture for better understanding what I want to achieve.
Message 4 of 8
(4,641 Views)
Hi there,
As I understood from the picture that you have attached, the append should start from the 5 seconds on the x-axis.
When you add a new plot, you can set the WaveformPlot.DefaultStart property which tells the graph where to start plotting.
If this is not what you are looking for, please attach a sample project and detail us about the requirement so that we can help you better.
Vijet Patankar
Message 5 of 8
(4,606 Views)
Hello vcp,
I know the DefaultStart property, the problem is that the gap should be made in one and the same plot. So this is not a different plot where I could set the DefaultStart property.
Message 6 of 8
(4,600 Views)
You can make a plot look broken in several ways.
Solution 1: Easy way
Set WaveformPlot.ProcessSepcialValues to true. Now, in the data plot Double.Nan to get a break in the plot.
            waveformPlot1.ProcessSpecialValues = true;
waveformPlot1.PlotYAppend(new double[] { 2, 3, 7, 5, double.NaN, double.NaN, 6, 9, 8, 4 });
Solution 2:  Not so easy way
1) Hook on to the Plot.BeforeDraw, and cancel the plot drawing. And do the following in the event handler.
2) Get the pixel coordinates for the break using WaveformPlot.Map(..). (Here we calculate start position and end position of the break in the pixel coordinates from the data coordinates).
3) Draw the plot to a temp Bitmap.
4) Once you know where the break appears in the pixel coordinates, use  Bitmap.SetPixel(...) method to set pixels in the rectangular region to Color.Transparent.
5) Use the grahics object from the event args to draw an image on the Plot area bounds.
6) Done.
Hope this helps.
Vijet Patankar
NationalInstruments.
    class MyPlot : WaveformPlot
        int stopDrawingPoint = 2, skipPoints = 2;
        public int StopDrawingPoint
            get
                return stopDrawingPoint;
        public int SkipPoints
            get
                return skipPoints;
        //protected override void OnBeforeDraw(BeforeDrawXYPlotEventArgs e)
        //    e.Cancel = true;
        //    Graphics g = e.Graphics;
        //    double[] xData = e.Plot.GetXData();
        //    double[] yData = e.Plot.GetYData();
        //    double[] xDataBeforeBreak = GetPointsBeforeBreak(xData);
        //    double[] xDataAfterBreak = GetPointsAfterBreak(xData);
        //    double[] yDataBeforeBreak = GetPointsBeforeBreak(yData);
        //    double[] yDataAfterBreak = GetPointsAfterBreak(yData);
        //    Bitmap b = new Bitmap(e.Bounds.Width, e.Bounds.Height);
        //    Graphics gg = Graphics.FromImage(b);
        //    e.Plot.DrawLines(new ComponentDrawArgs(gg, e.Bounds));
        //    g.DrawImage(b, e.Bounds.Location);
        //    //PointF[] pointsBeforeBreak = e.Plot.MapDataPoints(e.Bounds, xDataBeforeBreak, yDataBeforeBreak);
        //    //g.DrawLines(new Pen(e.Plot.LineColor), pointsBeforeBreak);
        //    //PointF[] pointsAfterBreak = e.Plot.MapDataPoints(e.Bounds, xDataAfterBreak, yDataAfterBreak);
        //    //g.DrawLines(new Pen(e.Plot.LineColor), pointsAfterBreak);
            e.Cancel = true;
        private double[] GetPointsAfterBreak(double[] data)
            double[] newData = new double[data.Length - (stopDrawingPoint + skipPoints)];
            for (int i = 0; i < newData.Length; i++)
                newData[i] = data[i + stopDrawingPoint + skipPoints];
            return newData;
        private double[] GetPointsBeforeBreak(double[] data)
            double[] newData = new double[stopDrawingPoint];
            for (int i = 0; i < stopDrawingPoint; i++ )
                newData[i] = data[i];
            return newData;
Message 7 of 8
(4,594 Views)
Thanks! This solution (Solution 1) works perfectly!!
Message 8 of 8
(4,580 Views)
