Confirming that I'm getting all samples
Hello--
I have an application where I'm sending a 100Hz pulse to a device and I'd like to measure 27 analog inputs for each cycle of the pulse.  My DAQ is an NI-USB 6363 OEM.
I've configured the task to trigger off the counter output (PFI12 in this case), and have the system capturing a finite number of samples for each cycle (1M samples /27 channels @ 100Hz = 370 samples per cycle).  Despite this, I seem to be only getting about 22-24 samples for every 100 cycles.  I'm not getting any buffer overruns, so I'm not sure where the data is going.  Below is my code:
Public Function StartPulse(ByVal CycleParams As CycleParameterType, ByVal SampleRate As Double, ByRef ErrMsg As String) As Boolean
        With CycleParams
                PressHiTime = .PressureOnTime / 1000
                PressLoTime = (.Period - .PressureOnTime) / 1000
                VentHiTime = .VentOnTime / 1000
                VentLoTime = (.Period - .VentOnTime) / 1000
                VentLagTime = (.LagTime) / 1000
                SamplesPerSnap = Convert.ToInt32(SampleRate * .Period) / 1000
        End With
        If AIRunningTask Is Nothing Then
            Try
                AITask = New Task()
                AITask.AIChannels.CreateVoltageChannel("/" & DAQName & AIPort, _
                                                       "AnalogInputs", AITerminalConfiguration.Rse, AIMinVoltage, AIMaxVoltage, AIVoltageUnits.Volts)
                AITask.Timing.ConfigureSampleClock("", SampleRate, SampleClockActiveEdge.Rising, SampleQuantityMode.FiniteSamples, SamplesPerSnap)
                AITask.Triggers.StartTrigger.ConfigureDigitalEdgeTrigger("/" & DAQName & PressurePulseOutputChannel, DigitalEdgeStartTriggerEdge.Rising)
                AIReader = New AnalogMultiChannelReader(AITask.Stream)
                AIRunningTask = AITask
                AIReader.SynchronizeCallbacks = True
                AITask.Control(TaskAction.Verify)
                'Pressure Signal Generation
                PressurePulseTask = New Task()
                PressurePulseTask.COChannels.CreatePulseChannelTime("/" & DAQName & PressurePulseCounter, _
                                                            "PressureSignal", COPulseTimeUnits.Seconds, COPulseIdleState.Low, _
                                                            0, PressLoTime, PressHiTime)
                PressurePulseTask.Timing.ConfigureImplicit(SampleQuantityMode.ContinuousSamples)
                'Vent Signal Generation
                VentPulseTask = New Task()
                VentPulseTask.COChannels.CreatePulseChannelTime("/" & DAQName & VentPulseCounter, _
                                                            "VentSignal", COPulseTimeUnits.Seconds, COPulseIdleState.Low, _
                                                            VentLagTime, VentLoTime, VentHiTime)
                VentPulseTask.Triggers.StartTrigger.Type = StartTriggerType.DigitalEdge
                VentPulseTask.Triggers.StartTrigger.DigitalEdge.Edge = DigitalEdgeStartTriggerEdge.Rising
                VentPulseTask.Triggers.StartTrigger.DigitalEdge.Source = "/" & DAQName & PressurePulseOutputChannel
                VentPulseTask.Timing.ConfigureImplicit(SampleQuantityMode.ContinuousSamples)
                'Count the Signals
                CountPulseTask = New Task()
                CountPulseTask.CIChannels.CreateCountEdgesChannel("/" & DAQName & CountPulseCounter, _
        "CountPulses", CICountEdgesActiveEdge.Rising, 0, _
        CICountEdgesCountDirection.Up)
                CountPulseTask.CIChannels.All.CountEdgesTerminal = "/" & DAQName & PressurePulseOutputChannel
                CountPulseReader = New CounterSingleChannelReader(CountPulseTask.Stream)
                'Start 'em up!
                CountPulseTask.Start()
                VentPulseTask.Start()
                AIReader.BeginReadWaveform(SamplesPerSnap, AIAsyncCallback, AITask)
                PressurePulseTask.Start()
                Debug.Print(AITask.Timing.SampleClockSource)
            Catch ex As Exception
                AIRunningTask = Nothing
                AITask.Dispose()
                StatusCheckTimer.Enabled = False
                ErrMsg = ErrMsg & " " & ex.Message
                StartPulse = False
                Exit Function
            End Try
        End If
        StartPulse = True
    End Function
    Private Sub AICallback(ByVal ar As IAsyncResult)
        Dim ErrMsg As String = ""
        Try
            If (Not (AIRunningTask Is Nothing)) AndAlso AIRunningTask Is ar.AsyncState Then
                ' Retrieve data
                AIData = AIReader.EndReadWaveform(ar)
                'Plot your data here
                DataToQueue(AIData)
                AIReader.BeginMemoryOptimizedReadWaveform(SamplesPerSnap, AIAsyncCallback, AITask, AIData)
            End If
        Catch ex As DaqException
            DAQError = ex.Message
            StopPulse(ErrMsg)
        End Try
    End Sub
    Private Sub DataToQueue(ByVal sourceArray As AnalogWaveform(Of Double)())
        Dim i As Byte = 0
        Dim tmpstr As String = ""
        Dim tmpAIdata(NumChannels - 1, SamplesPerSnap - 1) As Double
        Dim dataCount As Integer = sourceArray(i).Samples.Count
        For i = 0 To NumChannels - 1
            For j As Integer = 0 To (dataCount - 1)
                tmpAIdata(i, j) = sourceArray(i).Samples(j).Value
            Next
            If i = SystemPressureChannel Then
                AIPressure = tmpAIdata(i, dataCount - 1)
            End If
        Next i
        AISnap.Add(tmpAIdata)
    End Sub
Any thoughts on what the problem is?  Do I need to configure the sample clock source?Thanks!!!Sandheep
(2,581 Views)
If you execute the code with only one channel are you seeing the same behavior?
Dane S.
Product Support Engineer
(2,559 Views)
Dane--
Thanks for the response.  I did not try that, but remedied the situation by switching to a solution based on the ContAcqVoltSmpls_EveryNSamplesEvent example.
That seemed to be the only option that did not use Endreadwaveform.  Perhaps I don't understand how things work, but it seems to be that if you have an async callback that has an endreadwaveform, data handling code, and beginreadwaveform, then there is a possibility to lose data in between the endread and beginread, right?  Or is the data streaming constantly, and endread finishes a "sip" of data, while beginread begins a "sip"?
Please let me know what you think.
Thanks!
Sandheep
(2,555 Views)
