02-01-2011 02:55 AM
Erreur 1 Le type 'NationalInstruments.ComplexDouble' est défini dans un assembly qui n'est pas référencé. Vous devez ajouter une référence à l'assembly 'NationalInstruments.Common, Version=8.1.20.415, Culture=neutral, PublicKeyToken=4544464cdeaab541'. C:\Users\Frédéric\Documents\Visual Studio 2008\Projects\c#projects\softJan2011\LinearAlgebra\cs\MainForm.cs 1624 18 LinearAlgebra.2008
this what i get trying t set up a already used program
refernced assembly are the following
analysis.entreprise
common
.net
.networksvariable
.tdms
.UI
.UIWindowsForm
cvi version 8.9.0.246 under windows7 32bits
then the following error
Erreur 2 La méthode surchargée correspondant le mieux à 'MPOLARDEC.POLAR.Muellerbestcloude(ref double[*,*], out NationalInstruments.ComplexDouble[*,*], out NationalInstruments.ComplexDouble[], out NationalInstruments.ComplexDouble[*,*], out NationalInstruments.ComplexDouble[*,*], out NationalInstruments.ComplexDouble[*,*], out NationalInstruments.ComplexDouble[*,*], out NationalInstruments.ComplexDouble[*,*], out double[*,*], out double[*,*], out double[], out double[], out int)' possède des arguments non valides C:\Users\Frédéric\Documents\Visual Studio 2008\Projects\c#projects\softJan2011\LinearAlgebra\cs\MainForm.cs 1624 27 LinearAlgebra.2008
Erreur 3 Argument '2' : impossible de convertir de 'out NationalInstruments.ComplexDouble[*,*] [c:\Program Files\National Instruments\MeasurementStudioVS2008\DotNET\Assemblies\Current\NationalInstruments.Common.dll]' en 'out NationalInstruments.ComplexDouble[*,*] []' C:\Users\Frédéric\Documents\Visual Studio 2008\Projects\c#projects\softJan2011\LinearAlgebra\cs\MainForm.cs 1625 34 LinearAlgebra.2008
The program was working in an earlier version of cvi
02-10-2011 03:07 AM
HELLO,
What's driver you use?
Brice S.
National Instruments France
