Change programmatically the range of SliderDouble component
Do you know how to programmatically change the minimum and the maximum value of a SliderDouble component?
I've tried using the property "Range" but Maximum and Minimum fields are in read-only.
Thank you in advance for your help.
Cyrill
(5,324 Views)
You can set the Range property to a new value, instead of setting the sub-properties on the range. For example, to change just the minimum and keep maximum the same:
    slider.Range = new Range<double>( -1.0, slider.Range.Maximum );
~ Paul H
(5,319 Views)
Works perfectly!
Thanks Paul Smiley Happy
(5,313 Views)
