Change Counter sample to read dynamically and sample the card every 200 millisecond.
I am using a PCI-6602 card and I need to sample the card every 200 millisecond.
According to the "MeasDigFrequency_LowFreq1Ctr" example, I have implemented a code that samples the frequency continuously.
My problem is that if I set the variable SamplesPerChannel to be 1, when my frequency is 1 KHz, I receive many callbacks which is too much and affects the performance. If I set SamplesPerChannel to 20, and the actual frequency is 2Hz, I receive callbacks every 10 second which is not enough.
I try to use another method, according to the "CountDigEvents" example, I have implemented a code that read every 200 millisecond the numbers of event that occur in that period of time (which is supposed to be equal to the frequency). However, I cannot calculate exactly the frequency due to windows clock accuracy.
  1. Is there a way to set the SamplesPerChannel dynamically? (when the task is already running)
  2. Could I read every 200 millisecond all the samples (frequency) that are arrived from the last point of my last reading?
Simon.
(3,391 Views)
Hello Simon,
To answer your first question, whether or not you can set the SamplesPerChannel dynamically is determined by the card you're using. I looked it up and the PCI-6602 card does not have this functionality enabled.
As far as your second question goes, I would institute a 200 millisecond wait in the while loop that is reading the data. Then, if you set number of samples per channel to -1, it will empty the buffer entirely every 200 milliseconds. I made some sample code in LabVIEW that you can see below.
Hope this helps answer your questions.
Zoe B.
Account Manager - Pacific Northwest
(3,343 Views)
Hello Zoe,
I don't know LabVIEW. I work in C#.
Could you please write the example in C#?
Simon.
(3,327 Views)
Hi Simon,
I am not a fluent coder in C#, but the LabVIEW code I sent is actually just a shipping example that I modified slightly. As such, there's a corresponding C# shipping example you could use as a reference called Measure Digital Frequency - Low Frequency - 1 Counter.
A list of all the shipping examples and how to access them are found here.
Since the inputs/outputs of the functions are the same in LabVIEW as C#, you would change the corresponding number of samples per channel value to -1 and institute a wait within the while loop.
Zoe B.
(3,319 Views)
