Cannot add reference for NationalInstruments.DAQmx.dll
I am writing DAQ application using C# and I need to add reference to NationalInstruments.DAQmx.dll to be able to write analog output to device.
I found the NationalInstruments.DAQmx.dll located in C:\Program Files\National Instruments\MeasurementStudioVS2005\DotNET\Assemblies\Current folder.
However when I try to add reference for this file in my project using Visual Studio 2005, I am getting error that it is not COM component.
I am using Measurement Studio 8.0 and NI-DAQmx 8.3 driver.
Does anyne know the cause. Does anyone know a workaround.
(7,465 Views)
Hi Anurag_Chauhan,
I'm not sure how you're referencing the dll, but you should try something along the lines of
Imports
NationalInstruments
Imports
I would take a look at one of the shipping examples to see how it is done. For .Net, you can find examples in this file path:
C:\Program Files\National Instruments\MeasurementStudioVS2005\DotNET\Examples\DAQmx
There are several from "Analog Out" that should get you started.
Hope this helps,
Andrew S.
(7,451 Views)
I was trying to add reference from Visual Studio using "Add Reference" option. I figured out that it was not showing NationalInstruments.DAQmx as the .NET or COM component available to be added because I was using Visual Studio 2003 which uses .NET 1.1 framework and I probably did not enable support for .NET 1.1 at the time of install. When I tried to add refernece by selecting DLL using browse option to pick the file I got error because the file is a .NET 2.0 assembly and thus .NET 1.1 did not recognize the format.
When I opened the project in Visual Studio 2005 I was able to add refernece. Then I was able to access the class (via "using" for C#, via "Imports" for Java). Thanks for your help.
(7,445 Views)
This does not work for me
(6,630 Views)
Hello Megger,
What exactly doesn't work for you?  Are you receiving the same error as the above post, and if so what software are you using?
(6,602 Views)
