Can't install M S 7 because of no .NET Framework can't install .NET framework
Okay, I can't install M S 7 because it says I am lacking .NET framework. The Dialog Box points me to this link http://msdn.microsoft.com/netframework/downloads/howtoget.asp which does not exist however a howtoget.aspx link does exist.
The page says general users install through windows update --- I've tried that twice and nothing in the way of .NET framework appears.
The page also says for developers to go to the microsoft download site. I've done this and downloaded
The Get NET framework 1.1 SDK
and The Get NET framework 1.1 redistributable
When I go to install these I get a message that I can't without .NET framework
What am I missing?????
(3,704 Views)
These may be the links that you've already looked at, but just in case, check this out:
Both of these should install the .NET Framework 1.1 on your system, and the latter will also install the .NET Framework SDK. Hope this helps.
- Elton
(3,704 Views)
