Can I develop a device simulator using C#.NET and GPIB Interface card
I am trying to develop a device emulator on a Windows XP. I have another machine that is a controller and I want to test that it is issuing the correct commands.
I am using C#.NET. I have all the latest drivers installed. I have referenced NationalINstruments.Common and NationalInstruments.NI4882 in my Visual Studio Project. I have created a device object but I am unsure how to set up an event that will listen for communication from the Controller.
Is it possible to write an application that will react to a controller on another computer and respond like a device on the GPIB Bus?
If there are tutorials out there about this please point me in the write direction.
Greg
(5,247 Views)
Hi Greg,
The GPIB devices don't do this naturally, but you can write code that will listen for a certain amount of time then process a command if one came in.  There's a Knowledge Base article on PC to PC communication with GPIB and there is an example in C.  http://digital.ni.com/public.nsf/allkb/9CC0939663F1C5DE862565D70082E89E?OpenDocument  This won't include a true interrupt if a command comes in, but it will allow you to make a reasonable simulator.
Caleb W
(5,210 Views)
