04-25-2007 07:26 PM
04-27-2007 07:09 AM
Hi Matt,
You have a couple of options here which include:
- First, you could always have several waveformPlot objects and called the PlotY or PlotYAppend (depending if you wanting charting
or plotting behavior) on those waveformPlot objects. This is shown in the PlotsVsCharts shipping example (<MeasurementStudioVS2005>\DotNet\Examples\UI\WIndowsForms\Graph\
directory) and I have attached a screenshot of that example ("Plots vs
Charts.jpg")
- Use the waveformGraph.PlotYAppendMultiple or PlotYMultiple
methods which plots a 2D array of y values with the default data orientation
against the default starting x value. Check out the Plotting example (same directory as mentioned above)
that plots several objects at once (see attached "Plotting.jpg"
snapshot).
Honestly, since it appears you are just staring out, I would check out that
whole Graph directory as there are lots of examples to go off of. I would also
strongly encourage you to check out the Using the Measurement Studio Windows
Forms Scatter and Waveform Graph .NET Controls help topic in the NI
Measurement Studio Help.
Best Regards,
04-27-2007 07:30 AM
