C# Express: DAQmx.dll targets a different processor/ assembly not referenced.
My apologies for the double post, but I am having warning adn errors in Visual C# 2010 Express that I cannot resolve.
Warnings:
Referenced assembly 'NationalInstruments.Common.Native.dll' targets a different processor'
Referenced assembly 'NationalInstruments.DAQmx.dll' targets a different processor'
Errors:
The type 'NationalInstruments.ISupportSynchronizationContext' is defined in an assembly that is not refereced. You must add a reference to assembly 'NationalInstruments.COmmon, Version =9.0.40.610, Culture=neutal, PublicKeyToken=dc6ad606294fc298'.
The type   'NationalInstruments.ISupportSynchronizeCallBacks' is defeined in as assembly that is not referenced.  You must add a reference to assembly 'NationalInstruments.Common, Version=9.0.40.610, Culture=neutral, PublicKeyToken=dc6ad606294fc298'.
I have tried referencing the DAQ assemblies located at:
C:\Program Files (x86)\National Instruments\MeasurementStudioVS2010\DotNET\ Assemblies (64-bit)\Current\NationalInstruments.Common.Native.dll
C:\Program Files (x86)\National Instruments\MeasurementStudioVS2010\DotNET\ Assemblies (64-bit)\Current\NationalInstruments.DAQmx.dll
I have also tried using the directories:
C:\Program Files (x86)\National Instruments\MeasurementStudioVS2010\DotNET\Assemblies (64-bit)\9.0.40.610\
and have also tried adding the *.dll's to the same directory as my code.
In an attempt to change the target processor in Express, I have tried adding:
{PlatformTarget>x86<PlatformTarget>
in the project file of the XML editor as I read on another forum.
Any help and suggestions are greatly appreciated.
Thanks.
(4,628 Views)
In your project properties you must use .NET Framework 4 as Target framework,
not .NET Framework 4 Client Profile!
I hope this was what you need.
(4,515 Views)
I too am having the same problems as described previously, but the resolution described has not provided respite.
I have included an english version of the example settings and errors as an example.
Please, any suggestion would be tendered with an epiphanic moment!
Thank you!
Marcus
(3,929 Views)
Are you seeing the same targeting issues as the previous issue? or are you only seeing the assembly is not referenced issue?
Why Am I Getting a Warning Saying My Referenced Assembly Is Targeting a Different Processor?
http://digital.ni.com/public.nsf/allkb/63DDFC99B9951B418625796E002DDB09?OpenDocument
Additionally, do you have NationalInstruments.Common Version 9.0.40.610 referenced or is there a different version currently installed? Also i notice you have NationalInstruments.Common.Native referenced, you may have to reference NationalInstruments.Common instead. What versions Visual Studio and Measurement Studio are you using?
Also, if you create a new thread about this issue, it is much more likely to get noticed by forum members and answered quickly. It would be a good idea to provide a link to this thread in that post as well as details about the specific errors and questions from above and when they are recieved.
Evan See
(3,887 Views)
