Bessel Filter code for equiv: LabView "init/cont" for filter pre conditions.
Meas.Studio 10: looking for equiv code that's emulates the "init/cont" (T/F) setting in LabView for setting initial conditions or past filter condition for a Bessel Filter application.
(3,270 Views)
It looks like you'd utilize the Reset method when we'd want to clear the filter history instead of continuing from the previous data.
http://zone.ni.com/reference/en-XX/help/372636F-01/mstudiowebhelp/html/9b7f1e47/
R Dahlman
(3,236 Views)
Ch0MinusCh1HPFStorageBuffer = newHPFilter1.FilterData(Ch0MinusCh1_StorageBuffer)
this is the only code I am using. No reset method, want just Continuous, is this default? If so It not reflected in my output. Again this is a continuous a/d conversion with 1K buffers every 5ms for real-time application. Each buffer update has discontinuity at the boundary conditions.
" just want continuous all the time."  There are 12 methods in table, Reset is 1 of them but I don't have any idea what methods if any need to be called.
(3,228 Views)
From the help page, it seems like the default behavior should be continuous, and if we want to clear out the old data, we'd use the Reset function.
Is this not the behavior you are seeing in your code?
(3,211 Views)
That's correct, I am NOT using the reset function and want the default but my output is if the Reset function is/was called.
    Borgman.
(3,177 Views)
Would you be able to post a file with your code so that we can test and take a look into it?
(3,166 Views)
