Any examples using DigitalMultiChannelWriter.WriteWaveform available?
All I want to do is write a half-second pulse on a single digital line of a PCI-6515 board. I figure I should be able to use DigitalMultiChannelWriter.WriteWaveform with the waveform being a simple pair of 0 and 1 values. Going through NI Measurement Studio help I see I'm going to need to use DigitalWaveform which then leads to a whole bunch of other things. Before I spend a full day playing around with this, does anyone have any example code of a very simple application such as mine?
Tim
(4,222 Views)
Hello Tim,
When you install DAQmx after Measurement Studio, you should have a number of examples installed with it.  By default, this is located C:\Documents and Settings\All Users\Documents\National Instruments\MStudioVS2008\DotNET\Examples.  You can then open up NI-DAQ and look for Digital I/O.  This will most likely be in this folder: C:\Documents and Settings\All Users\Documents\National Instruments\NI-DAQ\Examples\DotNETx.x\Digital\Generate Values\WriteDigChan where the "x.x" will be whatever version of .NET you have installed.  Hope this helps!
ColeR
Field Engineer
(4,197 Views)
Cole,
Actually, no it doesn't help. That example doesn't involve the WriteWaveform function at all. In fact, I can't find any examples in the folder that do.
Tim
(4,194 Views)
Hello Tim,
You actually won't have to write a waveform.  You can just use the function writer.WriteSingleSampleMultiLine() to set your line to high and then 1 half second later, write it back to zero.  If you require this to happen multiple times you can loop it.  If you need a very exact half second (within µs), then you should just use a counter to output a pulse.
As this is just a high and then a low, you won't really need to output a digital waveform.  Waveforms are more generally used when you have a specific pattern that you want to output.
ColeR
Field Engineer
(4,183 Views)
