Any Sample code for continous data collection using NIDAQ and Visual C++.NET
Any sample code for aquiring continous analog data into a circular buffer in an asyncronous fashion using NIDAQ and Visual C++.NET?
(4,927 Views)
Hello
This code should be the same as any of our double buffered examples using NI-DAQ. You are still going to be using unmanaged code in most cases, so when using Visual C++, you can avoid the whole hassle of making wrappers for your dll calls. Check out this example to see which functions to call to set up the aquisition. Everything should be the same for VC++ .NET.
Bilal Durrani
NI
Bilal Durrani
NI
(4,926 Views)
