AnalogOutput BeginWriteMultiSample - when is Callback executed?
The BeginWriteMultiSample method for analog output has a callback.
When exactly is this callback executed?
Example:
I write samples for 10 seconds to the buffer (writing should last a few milliseconds if buffer has space).
Is the callback executed after writing to the buffer is finished (= few milliseconds if buffer has space) or is the callback executed after the samples has been generated at the output (= at least 10 seconds).
I hope, it will be executed after writing to the buffer is finished, because then you can easily use it to generate continuous analog output.
(4,205 Views)
Seems like the CallbackMethod is called quite immediately, which means it is called after writing into buffer (but not analog output) is finished.
I seems like I can't use the CallbackMethod to immediately begin another writing without using any timeouts. Right?
I am missing examples or documentation about how to use the callback for continuous analog output 😞
(4,197 Views)
Accepted by topic author Camell
Hi Camell
i hope this explanation helps a little bit
When Do DAQmx Analog/Digital WriteMultiSample Methods Return?
Have you looked into the examples?
best regards
Alexander
(4,186 Views)
