Adding cursor causes out of memory exception to WaveformGraph
I am working with some fairly large datasets and many charts. I have done this in the past with the ActiveX controls and it worked fine.  Using the .Net charts causes a massive spike in memory when adding a cursor.  It's almost as if the entire plot data for each plot is copied to another array when creating a cursor.  I tried to add the cursors before the data but they cannot be made visible afterwords.  Is there an optimum way of dealing with cursors in the new .Net controls?
(4,589 Views)
Hi justwakingup,
Have you taken a look at an example to get an idea of how they are typically setup?
KyleP
(4,578 Views)
