AI-AO delay
I am trying to build simple program that would sample from analog input and play it on the audio output.
I wrote the following code in C# (even though the problem exists in C either) http://pastebin.com/DeQFzkBw and when I am running it on my myDAQ I am having a delay of about 1.2 seconds!
What am I missing?
Thanks!
Lev
(5,289 Views)
Hi levp92,
Have you looked at any of the C# examples that come with measurement studio?  There are examples for analog IO there that can help you at this location: C:\Users\Public\Documents\National Instruments\MStudioVS2010\DotNET\Examples .  Hope this helps!
Dayna P.
(5,257 Views)
My program is based on this examples, but still has this problem.
Do you have any other suggestions?
Lev
(5,247 Views)
Hi Lev,
You are currently reading chunks of 5000 samples at a time.  After you sample all of the data, you are processing all of the data.  Then finally you are displaying it.  Sampling and processing that much data can take a lot of time, and might be the source of the delay.  I recommend reducing numberofsamples down to a much smaller number, such as 5, and then running it, and then see what the delay is.
Hope this helps!
Dayna P.
(5,230 Views)
