A question about FSEA30 hardcopy GPIB remote control?
HI
    I  have implemented some basic functions.Now I want to use the remote print screen, but there are some problems:
1,use viReadToFile ,the documents are only have 4096kb
2,use viRead,Program death
    This is my VB.NET source with viReadToFile code:
Private Sub FSE_btnHDCP_Click(sender As Object, e As EventArgs) Handles FSE_btnHDCP.Click
         status = viVPrintf(vi, ":SYST:COMM:GPIB:RTER EOI" + vbCrLf, 0) '此命令更改分隔符。
        status = viVPrintf(vi, ":HCOP:DEV:LANG WMF" + vbCrLf, 0) '设置WMF格式
        status = viSetAttribute(vi, VI_ATTR_TMO_VALUE, 20000) '设置超时
        status = viVPrintf(vi, ":HCOP:DEST1 'MMEM'" + vbCrLf, 0) '
        status = viVPrintf(vi, ":MMEM:NAME 'C:\USER\DATA\FILE.WMF'" + vbCrLf, 0) '
             status = viVPrintf(vi, ":HCOP" + vbCrLf, 0) '开始
        status = viVPrintf(vi, ":MMEM:MSIS 'C’" + vbCrLf, 0) '
        status = viVPrintf(vi, ":MMEM:CDIR '\USER\DATA\'" + vbCrLf, 0) '
        status = viVPrintf(vi, ":MMEM:DATA? 'FILE.WMF'" + vbCrLf, 0) '
        status = viRead(vi, strRes, 16, retCount)
        Dim x As Integer = Val(Mid(strRes, 2, 1))
        Dim y As Integer = Val(Mid(strRes, 3, x))
        status = viReadToFile(vi, "D:\YouName.WMF", x + y + 2, retCount) '最大4096,且写入不覆盖。retCount正常
        status = viSetAttribute(vi, VI_ATTR_TMO_VALUE, 2000) '设置超时为默认2秒
    End Sub
      This is my VB.NET source with viRead code:
        Threading.Thread.Sleep(2000)
        status = viRead(vi, strRes, x + y + 2, retCount) '太长时读出为空,容易卡死
        If (status < VI_SUCCESS) Then
           MsgBox(" Failed to read from the instrument! ")
        End If
        VI_txtOUT.Text = VI_txtOUT.Text & retCount
        If strRes = “” Then
             MsgBox(“nothing”)
         Else
             strRes = Mid(strRes, x + 3, y)
             FileOpen(1, Application.StartupPath + "\YouName.WMF", OpenMode.Output) '输出文档
             Print(1, strRes)
             FileClose(1)
         End If
    End Sub
(2,495 Views)
if use  viVScanf or  viVQueryf like:
status = viVScanf(vi, "%t", strRes)
status = viVQueryf(vi, ":MMEM:DATA? 'FILE.WMF'“ + vbCrLf, "%t", strRes)
Sometimes the result is empty, and sometimes the result is “#572676淄茪”
(2,485 Views)
