30 day evaluation message
I have built my application using VS.Net 2003 and MS.Net 7.0. The app has both .Net graphs and Active X Gauges. I get a 30 day evaluation version message. After 30 days the controls do not work (as was mentioned in the aforementioned message).
Firstly I have posted a message similar to this one in the past. I found the reply I got from an NI engineer. I was directed to go to the following URL:
http://digital.ni.com/public.nsf/websearch/ED87C183E056CAC386256DF1004E54C6?OpenDocument
and I followed the steps (but no where did it address my issue directly).
I run the setup program and I still get the 30 day message.
What should I do to get around this.
Thank you,
~Sinisa Stokic
(3,703 Views)
Hi Sinisa,
Try running the license fixer on the machine you have placed the application on. This should fix any unlicensed ActiveX controls that may be causing you trouble. You can find the license fixer at:
http://digital.ni.com/public.nsf/websearch/86256A47004E16D186256A99007BEFB7?OpenDocument
Let me kow how this works for you.
Caroline
Caroline Tipton
Data Management Product Manager
(3,691 Views)
Caroline,
I haven't tried your solution yet, but I do recall now that I was pointed towards this a long time ago. Thank you for your help. I suspect that this will do the trick.
~Sinisa
(3,684 Views)
