Measure
avarage calculation with array
hello i have the labview 8.5
an i must measure the temperature,,,,
with the labview i must:
with DAQ-assistent take the datas an show (every second (1hz)) it.......
 i must also take the avarage from the last 60 datas (1min) and save it in a excel file....i thought i take the 60datas in a for loop wire it in an array and then divide it through 60
CAN SOMEBODY HELP ME PLEASE
(7,783 Views)
You posted to the Measure board but also mention LabVIEW. Measure is an add-on to Excel that allows for data acquisition in Excel. So, what are you using, Measure or LabVIEW? If it's LabVIEW, post to that board or the Mulit-function DAQ board. It would also help if you attached your code.
(7,781 Views)
here there is the link to an example that acquires data and writes them in an Excel file in tablature and graph form:
http://zone.ni.com/devzone/cda/epd/p/id/25
In attachment there is an example about how to do the running average.
Serena
Applications Engineering
(7,765 Views)
