Measure
SCXI-1102: voltage measurement out of range
I have a SCXI-1102 module. The input voltage range is +/- 10V. I did not understand if I can make a direct measurement of a voltage higher than + 10V without using a voltage divider. For the interface, I use an SCXI-1303 terminal block.
(2,605 Views)
No, you cannot measure more than +10V without a voltage divider.
Santhosh
Soliton Technologies
(2,575 Views)
