Measure
Centroid 16bits
I have built an optical tweezer, throught an home made µscope and I measure the position of fluorescences balls ( 1µm to 200 nm) with 8bits labview centroid function.
My image are a 16bits and I oblige to cast into an 8bits Image before processing Centroid.
I would like to know, why a 16bits version doesn't exist ?
Does anyone know if we can programming a 16bits version, or Are others method exist to calculate the position in 16bits image on Labview?
PS : I have LV 8.0 and LV2010,
Thank you for all,
manu,
(5,878 Views)
Thanks for posting on NI forum.
You can see in the attached picture the compatibility of the NI vision module 2010. U16 and I16 are supported.
For the 2009, you can see here that only I16 is supported.
With Labview 2010 tou can use the centroid VI with 16bits images.
Nicolas M.
National Instruments France
Journées Techniques LabVIEW 2012 : du 27 septembre au 22 novembre
2 sessions en parallèle : Débuter avec LabVIEW - Développer avec LabVIEW
(5,871 Views)
