Measure
Calibration Executive fails to generate pdf reports
I have Calibration Executive 3.4.1 and it has stopped generating pdf, word, or excel reports. It still generates text and html reports. I reinstalled cal exec and made sure it as all the current updates. The only thing we changed lately was installing DAQmx-9.4. I rolled that back to DAQmx-9.3 which did not help. If the default report is set to pdf, no report gets generated. It also will not open any report done earlier. It give an error message stating the path is incorrect of the file is corrupted. The path is correct and the old pdf open just fine using Adobe (ver 8 standard). Has anyone experienced anything similar or has any advice as to what to look at next. Thanks for any help!!
(6,448 Views)
Accepted by topic author Mr_Metrology
Solution: the latest revision of JAVA was corrupted causing the error. Removal and re-installing a clean version of JAVA corrected the problem.
(6,446 Views)
