Machine Vision
why in inspection mode screen keeps flickering?
Hello all ... :)
    I'm using VBAI 3.5.... When I switch from configuration mode to inspection mode the screen keeps flickering.... And the charts on right side keep moving though the system is idle... Can anyone please tell me why this happens...? Or how to stop this happening...?
Thank you for any help from you.. 🙂
(3,335 Views)
Hi Rupali,
What do you mean by the chart is moving ?
Also what is the hardware you are using and what is the frame rate? Can you please give more description about your application.
Vaibhav
.......^___________________^
....../ '---_BOT ____________ ]
...../_==O;;;;;;;;_______.:/
.....),---.(_(____)/.....
...//____//......
..//____//......
.//____//......
(3,302 Views)
Hello Vaibhav....
    I have attached a pic of the charts which you can see on the left side of inspection mode in VBAI 3.5.... 🙂
(3,285 Views)
