Machine Vision
vison
hi sir:
i have see the Using the JAI CV-M10 Camera in Asynchronous Reset Mode with the IMAQ 1409 Document but my jai-cvm10 is rev.D so i use to docment
to connection 1409 but i can't get clear Image so how can i do.
my jai-cvm10 rev.D so no same as document have PK8190A Board (from JAI CV-M10 Operation Manual—Rev. F) so my camera is jai-cvm10 (rve.D), how can use the Asynchronous Reset Mode with IMAQ 1409 and jai-cvm10(rveD).
i need your help, thanks a lot
vovo
(3,132 Views)
Vovo,
It sounds as if you have a revision fo the camera from JAI that has features different than those used in the document for the JAI CV-M10 rev F. I would suggest you contact JAI to see what engineering design changes they made to the camera. JAI would be the best source for getting workarounds and possible solutions so that their camera supports these modes correctly.
Best Regards,
Chris
NI Applications Engineer
(3,132 Views)
