02-14-2020 11:35 PM - edited 02-14-2020 11:40 PM
Hi, I generated a labview vi for pattern matching using vision assistant ,that vi is workig well in my pc but when I am trying to deploy it in NIMYRIO1900 the code doesnot work please share the process of deploying the vi and where should I store the matching template as i want to switch leds on MYRIO when pattern is detected
02-21-2020 06:33 AM
Hi, could you tell me more detail about your comment “the code doesn’t work”? You failed to deploy the code on myrio? Or the deployment was successful, but the RTVI did not run in the way you were expecting? If you can share the vi, I recommend you to attach it here as well!
02-23-2020 02:22 AM
Hi sir thanks for the reply. I deployed the code in MyRIO as i did for other vi's but my RTVI did not run in the way I am expecting.my aim is to switch on led when the pattern detects the 70km/hr sign board .when i am running same vi in my PC it is detecting the board but when i do it in RIO atleast it is not detecting the pattern and showing error code. I searched the code in vision manuals which tells that template is not found but i loaded it in MYRIO . I request you to share your mail id or contact number as it will be usefull for me for effective communication to complete my academic project.
