Machine Vision
vision assistant structuring element
HELLO,
 I am a new bee to labview.My objective is to "ERODE OBJECTS" through  "BASIC MORPHOLOGY"  in vision assistant  using a 2 x 28 structuring element filter.But vision assistant only provides 3 x 3 , 5 x 5 and 7x 7 order structured elements erode object filter. Is there any way out??
        Thank you 🙂
(3,479 Views)
1.  When doing erosion, you need to use odd dimensions.  This gives you a center pixel.
2.  Anything bigger than 7x7 will have to be done using LabVIEW.  Make sure you make your image borders larger, also.
Bruce
Bruce Ammons
Ammons Engineering
(3,474 Views)
i got it...thank you Mr.Bruce Ammons for your reply..
(3,463 Views)
The latest version of Vision Assistant 2011 SP1 lets you specify much bigger kernels, but unfortunately, they still have to be the same size in X and Y. Thanks for the feedback. We might consider letting the user specify different sizes in X and Y in a future version.
As Bruce mentioned, you will have to generated the code and do it in LabVIEW.
Alternatively, you can just create that VI from LabVIEW using the kernel you want, call it using the Run LabVIEW step, and still do the rest of your prototyping in Vision Assistant.
Christophe
(3,456 Views)
