Machine Vision
video with pci1411 "can't lock on video source"
I am using a PCI 1411 and I have connected it with a VCR through the BNC output. The problem is that when I try to grab a picture it gives me the error "can't lock on video source". Also my video do not support any BNC connection so I had to use a connector to connect the video cable to the BNC cable and I don't know if this is the trouble.
I found some help pages of how to configure PCI 1411 with a camera but nothing to say about Video
(3,363 Views)
A couple of things to check:
Make sure the VCR is outputting video to the connector you are using. Some VCRs require selecting the output channel. Make sure a tape is playing to provide a usable signal.
If you are using a RCA to BNC converter, it should work fine.
Make sure you selected the configuration file with the appropriate input. If you select the S-Video input, the card will not see the signal on the BNC input. Make sure the signal format is also correct.
Bruce
Bruce Ammons
Ammons Engineering
(3,363 Views)
Thanks Bruce,
The RCA to BNC converter work perfect.
Momus
(3,363 Views)
