Machine Vision
unlicensed
Hello - I am trying to load NI-IMAQ Version 2.6.1 onto a new WinXP machine.  There is a LabView executable, version 7.0, that needs to run on this machine.  There is no internet connection.  After loading NI-IMAQ with the LabView 7.0 Support installed option selected, during the process I am never asked to register the product, I get an "unlicensed error" when trying to run the executable.  Please see attached image.  The interesing thing is that there is already a machine with the exact same version if NI-IMAQ in the lab that runs without this popup error.  I have tried unloading NI-IMAQ and reloading several times to no avail.  The Meas and Auto ver is 3.0.2.3005 on both machines.  (Also, installing newer versions of the NI-IMAQ causes the LabView executable to freeze, rendering it inoperable, so loading 2.6.1 seems to be my only option.)  Any help is greatly appreciated - Jeff
(3,180 Views)
Jeff,
    This is Allison from Applications Engineering.  I have spoken with you over the phone on this, you will need a license for the Vision Runtime Engine in order to run your exe on another computer.  I will call with more details later today.  Thank you!
-Allison S.
Calibration Services
Product Support Engineer
(3,152 Views)
