05-07-2010 11:49 AM
Hi everybody,
how can i two cameras whit a same name in Vision Builder AI identify like device 1 and device 2?
my problem is that i connect the two cameras but the VBAI identifies only one
thanks
05-10-2010 04:16 AM
Hi Jois
Check that both cameras are detected :
1 - in the Device Manager
2 - in MAX
05-10-2010 04:34 AM
05-10-2010 04:57 AM
05-10-2010 05:12 AM
Hi Doc-Doc,
thanks for your reply
in MAX there is only one camera und i have two USB ports and both normally work, but i can only one USB port use
i connect the camera in the other and don´t works . Maybe i muss configure the other port ?
thanks for your Help
Jois
05-10-2010 05:21 AM
05-10-2010 08:48 AM
From your posts in a bunch of other threads, it sounds like you are using IDS uEye cameras. Their DirectShow drivers show by default a single (virtual) device regardless of how many cameras (even 0) you have connected. You'd have to consult with them as to how to get their drivers to add more than one DirectShow interface.
Eric
