Machine Vision
two button dialog
hello. currently im doing a project to detect road marking using multiple geometric pattern matching. my idea was when the user has two choices the program will prompt the user to select which way to go. in my program i have used a "go left or right" marking and i planned to use two button dialog. however it only appears one time at the beginning of the program and didnt appear anymore. is it something wrong with the loop or in my program? or if you guys can share some idea how is best to prompt the user to make selection.
here i attach the program and also the templates. any help is much appreciated. thanks
Message 1 of 11
(5,469 Views)
I see your code it is not correct code you have too insert two button dialog part into your while loop otherwise it will be execute just once in any run
Message 2 of 11
(5,342 Views)
Outside the case structure a for loop is used. Do i have to change to while loop or it has to put at the while loop that contains vision acquisition?
Message 3 of 11
(5,340 Views)
second one
Message 4 of 11
(5,338 Views)
i have edited my program to add boolean as an indicator. but i still dont know how to connect the two button dialog and wire it to certain cases. in the program the two button dialog appears every time when an image is loaded. can u please share your idea? thanks a lot
Message 5 of 11
(5,328 Views)
could you explain exactly what you want to do please explain your idea
Message 6 of 11
(5,323 Views)
actually i want to detect the road markings on the road. there are two types of road markings which are a single option for examples straight only or right only. the second types of road marking has two option. for example either go straight or turn right. for this type of road marking, i want the user to make a choice which way he/she wants to go. thats why i want to put a two button dialog so that the option of go straight or turn right will come up. sorry for the confusion
Message 7 of 11
(5,320 Views)
Accepted by topic author hazik.
your code should be something like this
Message 8 of 11
(5,312 Views)
thanks a lot sir. i will try to apply it to my program
Message 9 of 11
(5,309 Views)
before continue just regard that this project is not so easy if you want to imply it to control car to driving on the rood
Message 10 of 11
(5,305 Views)
