Machine Vision
tracking centroid via (X,Y) motors
Hi all,
I am new in Labview, and i need to manage a small project.
This project is the next:
Through a video frame, i will acquire an object.
This object will be detected in a specific ROI and i will obtain the centroid.
Untill here, no problems
My main problem is how to comunicate the coordonates of the centroid to motors, to assume a tracking of the object through the webcam in X,Y axis.
Thanks for your help and support.
Christophe
(3,365 Views)
Subtract the desired location from the current location to get the error.  Multiply the error by a constant to get the motor output.  Repeat in a fast loop.
Larger constants give you faster motion, but too large will start oscillation and possibly mess up your hardware.
Bruce
Bruce Ammons
Ammons Engineering
(3,363 Views)
Hello Bruce,
Thank you for your point of view.
In fact, i know that because i was working in another software (Scilab).
My problem is how to use Labview...i don't know and because it's an obligation to use it, i need to go straight.
Regards and thank you
Christophe
(3,359 Views)
