Machine Vision
structure help on vision problem
i need help deciding what i need to do to execute a routine after a text file is created...since there is no error flow i have no way to executing a routine after the text file is created.. I need some serious help..i have included the vi below and the part i am workin on is in the save image routine. Everythign works well but as soon as the text file is created i need to send a data bit out to a machine...then loop to check when a data bit is sent back and complete the whole case when this is complete...thanks... it shoudl be easy for you labview experts....i appreciate ur time
(3,598 Views)
the part that needs work is unter the save image case and i commented areas that need to be looked at
(3,591 Views)
bump! can someone help me?Smiley Sad
(3,563 Views)
solved
(3,553 Views)
