07-24-2007 08:35 AM
07-24-2007 12:53 PM
Can you determine what the ideal timeout would be before starting the acquisition? I think you can set the timeout value when you setup the acquisition. If you know it should only take a few milliseconds, set the timeout to a second or two. If you are going to do a longer exposure, set the timeout longer.
I don't remember exactly how to set the timeout value, though. It may be an input on one of the setup vis, or it may be in a property node. You might have to search a little bit.
Bruce
07-24-2007 03:28 PM
