Machine Vision
software trigger vision builder
I am using a smart camera with vision builder 3.6
For the moment I have a very simple setup: a loop where I first acquire an image, then write to a local disk using ftp and finally a delay of a few seconds, which defines the rate of image acquisition.
I would like to be able to define the rate of image acquisition using shared variables (so I can define this from a LabVIEW program). First I thought to change the delay but I did not find how to link the value of a variable to the delay step.  My next thought was to have a software trigger. This would be the best solution but again here I could not find how to implement this in vision builder (in the trigger section of the image acquisition step I could only find hardware trigger options).
So my question is how to implement a software trigger on a smart camera running vision builder.
Thanks!
Ture
(4,151 Views)
Trying to change the delay using a shared variable was a good idea. We'll probably add in a future version the possibility of setting the delay to a previous measurement.
I am afraid that for the moment, the  only solution to do that is using the state diagram and have a first state that polls and detects the change in your shared variable and transition to the next state only when your variable is incremented. The acquisition occurs in a second state.
See attached example writtten in Vision Builder AI 3.6 and LabVIEW 8.5.1.
Hope this helps.
Christophe
(4,129 Views)
