Machine Vision
shading correction
I wonder if there is a precast possibility to run a shading correction on images. I didn'f find something like this - ideas?
(3,538 Views)
If your lighting is uneven, it is possible to correct the image. It depends on how uneven it is.
The basic idea is to average the brightness over a large area. The area must be 2 or 3 times larger than any details you are examining. For example, if you are trying to read some text that is 20 pixels high, you would want to use a 60x60 averaging filter to figure out the average intensity in that area. Once you have figured out the average background intensity, calculate a scaling factor for each pixel to get to a fixed brightness. Essentially, divide your desired background brightness by the pixel intensity. The final step is to apply this scaling to your original image.
Bruce
Bruce Ammons
Ammons Engineering
(3,538 Views)
