I am looking to create a VI which does pattern matching which is scale invariant, that is
If I creat a template which is smaller ot bigger than the target image it shoudl be able to
recognize it,no matter what. I created a vi which is attahced to this post. I am receiving an
error saying that this template doesnot have information for scale invariant matching. I am attching a snapshot of that too. The real time time image also is posted along with the template. Anyone.
Solved! Go to Solution.
Sorry
Forgot to add the error message. I am attaching it to this.
You can use a geometric pattern matching and use a line profile using the rectangle bounding box like this
Ok
That thread I posted was for color pattern matching and this is for grey scale.
yes they both are similar but not the same. I couldnot open your attachment.
could you post your code on what you did exactly. I have latest version, so I
am sure I can open anything.
The biggest question I have is did you use a single template for all the matches that you
shown in the screen shot above. If so can we do the same in color pattern matching in labview
or not.
WHAT THE HELL.
WHO LOGGED INTO MY PROFILE AND POSTED ABOVE TWO POSTS.
I didnot post the above two questions.
Yesh
I am so sorry, I was in the image processing lab.
You didnot logoff your profile, and in a hurry I posted
my requests without checking what profile I was logged
in. Those two posts were by me and later I tried to delete
them but couldnot.
I am so sorry. forget last post. I donot know whats wrong with that system.
Its going to your profile by default. I will make sure that it doesnot happen again.
Muks
you asked me to create a line profile using a bounding box.
I am not able to open the attachment you posted. can you
a screen shot of what you did.
Also neglect posts 5 to 9. My system in the lab was logged
into a different profile. Sorry for the commotion if you are
still not laughing.
