Machine Vision
rle
Dear forum members.
Who knows how to do compression and decompression by algorithm RLE "Run-length encoding"?
I have one hexacode string data, inside got compression by RLE and now i will do decompression, but i dont know how.
Could you help me to solve this problem?
Thanks in advance
With warm regards
Harutyun Melikyan!
(3,046 Views)
Hi, Melikyan,
Probably this will be helpful as starting point:
"...Run-length encoding (RLE) is a very simple form of data compression in which runs of data (that is, sequences in which the same data value occurs in many consecutive data elements) are stored as a single data value and count, rather than as the original run. This is most useful on data that contains many such runs: for example, relatively simple graphic images such as icons, line drawings, and animations.
For example, consider a screen containing plain black text on a solid white background. There will be many long runs of white pixels in the blank space, and many short runs of black pixels within the text. Let us take a hypothetical single scan line, with B representing a black pixel and W representing white:
WWWWWWWWWWWWBWWWWWWWWWWWWBBBWWWWWWWWWWWWWWWWWWWWWWWWBWWWWWWWWWWWWWW
If we apply the run-length encoding (RLE) data compression algorithm to the above hypothetical scan line, we get the following:
12W1B12W3B24W1B14W
Interpret this as twelve W's, one B, twelve W's, three B's, etc..."
best regards,
Andrey.
(3,037 Views)
