Machine Vision
resize rectangle without mouse
Good morning all,
I use NI vision tools in vb.net 2010 and i need to resize and rotate vision tools (rectangles in particular) without mouse, but creating a little form with buttons to resize width, height and angle. Is it possible?
I'm using VDM 8.6.4
Thank you in advance,
Massimo
(3,298 Views)
Hello Massimo,
Are you drawing ROI rectangles or Overlay pictures? You should be able to access manipulating functions for both objects, or better, gather example files from your Development System if you installed support for that tool.
Let me know which type of images you want to manipulate, then, we should be able to figure out the best steps you can take.
Best regards
Matteo
(3,282 Views)
