Machine Vision
real time color pattern matching
I am doing a project of color pattern matching in real-time. I want the pattern that is matched with the templete shows on the screen. I was trying to write some labview code but it only works for the first single image. The labview i use is 8.6. camera is the ieee 1394b firewire camera. I hope someone is capable of fixing my problem.
Thanks for any help.
Message 1 of 9
(4,870 Views)
Hi blue hill,
Can you post your vi for lv 8.0? or a screen shot of ur vi?
Message 2 of 9
(4,860 Views)
hi muks,
I dont have 8.0 version. Here is the screen shot.
Thanks.
Message 3 of 9
(4,849 Views)
What is the match score that you have set? Ideally 600-700 is the score that was recommended as a rule of thumb.
Message 4 of 9
(4,846 Views)
I didn't set the score. Yes, 700 can be as the minimum.
Message 5 of 9
(4,841 Views)
I just modified my vi a little bit. It can work well for the single picture on my computer. Both the image and templete image can be opened, and the detected image can be marked. Once I tuned the code to make it work for the images caputred by camera, the templete image seemed not be opened. I used the probe to find that.
Thanks for any help,
BlueBill
Message 6 of 9
(4,821 Views)
Hi! I'm tring to use Imaq Setup Learn Color pattern Vi. It has a tunnel in : Ignore color spectra. I read many posts, manuals, all of vision manuals ::) but i dont really understand how to use it. " For
example, by replacing the last component in the color spectrum with –1, the
white color is ignored during the color matching process.
". OK , but how to do that? anyway, i read this : Use the Color Sensitivity control of the IMAQ ColorLearn VI to
specify the granularity you want to use to represent the colors".  So, what I wanna do , how to use the color spectrum array (2dim) from Imaq Color Learn  as an input to the Imaq Setup Learn Color pattern vi, avoiding the error messasge like this : error2.JPG
Please help!
+++ In God we believe, in Trance we Trust +++
[Hungary]
Message 7 of 9
(4,783 Views)
hi durnek60,
why dont you start a new thread?
Message 8 of 9
(4,770 Views)
Hi muks! Sorry, but i don't understand... New thread? how? by the way, my problem is how to use ignore color spectra array in Imaq Setup Learn Color pattern vi.
[Hungary]
Message 9 of 9
(4,763 Views)
