Machine Vision
question about camera file generator
Dear all,
I was trying to set up my camera with the frame grabber using camera file generator. My camera is a linescan camera, which is 1024x1 pixels.
My question is, in the camera file generator, I can choose to display maximum number of rows which could be any number I key in, for example, I can choose to display 1024x256 or 1024x800.So since my camera has only one line of pixels, where are all the other rows come from?How does it work?
Thanks a lot!
(3,312 Views)
Hi
When you create your icd file, the height value, will be the maximum number of lines you can accumulate.
So when you will use your camera with MAX or LabVIEW, you can specify an image height within 1 and this value.
I suggest to set this value pretty high (10000 lines for instance) so that you are free to request a big image in your application.
Regards
(3,305 Views)
