Machine Vision
pci-1410, hr70 and imaq A6804
I have a problem to grab the image. I use the pci-1410 frame graber with imaq A6804 and sony camera hr70. the camera file, I downloaded from NI.
Do I need an other device ?
How to set the configuration of camera ?
Eagleamq
(3,286 Views)
Hello Eagleamq,
you are able to connect all analog cams with bnc interface to the A6804 connector block.
For the configuration of the cam you must open the Measurement & Automation Explorer on the desktop.
Under "device and interfaces" you can find the frame grabber card 1410.
An analog cam need a camerafile for the configuration.
You have to store your camera file in the folder "C:\Programme\National Instruments\NI-IMAQ\Data".
And with a right click on the cam (in MAX) you are able to choose the correct icd file for your cam.
But its not a problem if you dosent find a correct icd file for your cam.
You are able to try the standard rs 170 icd file you get the image.
Kind regards,
Elmar
(3,266 Views)
