Machine Vision
particle filter 2
I've got lv7 and vision7 installed - when I am trying to create a lvVI from a script in Vision Assistant the builder cannot find the VI: "Particle Filter 2" and asks for help. Where can I find this VI?
(3,571 Views)
This VI is located in the Morpho.llb in the folder:
C:\Program Files\National Instruments\LabVIEW 7.0\vi.lib\vision .
Hope this helps.
-Julie
(3,571 Views)
I guess that is where it is supposed to be, but it is not, only particle filter and no particle filter 2. Tried to reinstall but that did not work either.
(3,571 Views)
Try calling NI (go to ni.com/ask) and see if they can get you the VI... it is strange that you are missing certain VIs though.
(3,571 Views)
Fixed the problem, the installation had some problems removing the old vision edition, but after removing it manually and installing the new version it worked fine..
(3,571 Views)
