Machine Vision
overlay dont appear
I have a simple problem with overlay step. All I want is that when the step passes into an "Overlay" step, the text I created in the "Overlay" will appear. But it seems that when I run the program, the "Overlay" is nowhere to be seen and just run continuously.
Andrei K.
(3,228 Views)
Are you talking about a VBAI inspection, a LabVIEW VI, or are you using Vision Assistant? What kind of overlay are you trying to display and in what context?
John B.
Embedded Networks R&D
Certified LabVIEW Developer
(3,222 Views)
Accepted by topic author andrake
Good day Mr. JtotheB,
I already solved my overlay problem. I just forgotten to update the image in the "Update UI". Thank you very much.
Sincerely,
Andrei K.
(3,217 Views)
