Machine Vision
optical flow
Hello,everyone:
     I want to use the optical flow(KLP) in real-time.But,there is an problem "MAQ Vision:  Incompatible image size." Can anyone give me some advises?
Change the world
(5,813 Views)
try using IMAQ SetImageSize in the initialization stage for your "previous_image" reference.
Set the size according to the camera resolution.
K
https://decibel.ni.com/content/blogs/kl3m3n
"Kudos: Users may give one another Kudos on the forums for posts that they found particularly helpful or insightful."
(5,807 Views)
Klemen,
       Thank you very much. I  have added the IMAQ SETIMAGESIZE.vi before the"pervious_image",but the same problem is still happen.This time I put my vi on the web,can you help me ?
Change the world
(5,795 Views)
Klemen,
Change the world
(5,794 Views)
in the initialization of the "previous_image", you have incorrectly wired the width and height of the image (it is 480x640, instead of 640x480, which I assume your camera outputs).
In order to make the program immune to camera resolution changes, I advise you to use the width and height camera property and wire this to the setImageSize. Put a property node after the camera initialization and read the W/H attributes of the camera.
K
(5,767 Views)
