Machine Vision
[nipalk] Notice: ZwLoadDriver(niimaqk) failed at least once
Does anyone know about information in Event Viewer under Windows Logs>System, [nipalk] Notice: ZwLoadDriver(niimaqk) failed at least once?
I found this information appear on the event list frequently.
Most of the time, my application using LabVIEW and Vision Development Module will crash afterward, without Error message or anything but only LabVIEW closes it front panel.
Basically, my application is to read text using OCR Read Text from an image captured by GigE camera.
My environment is as below.
Windows 10 Pro
LabVIEW 2020
VDM 2021
VAS 2020
Please help. Thank you.
(1,562 Views)
Hi!
I have exactly the same problem.
Do you found a solution for this?
Thomas
(546 Views)
