the 2nd problem (Vision Assistant 7.1 and LV 8 -> the error message is a little bit dizzying...) occurs, because
Vision Assistant is/was for LV 7.x and not for LV 8. I think, you
have therefore 2 options, either to upgrade Vision to 8.0 or to use LV
7.1 to generate LV code, afterwards mass-compile the vi's in LV 8.
For this issue, please contact your local office to clarify the circumstances!
Do you see the IMAQ1394 device in MAX?
If it's possible to expand the IMAQ 1394 device entry, make a right
click on the expanded device and change the driver from "Standard 1394
Desktop Camera" to "NI-IMAQ 1394 ...."
Hope this helps,
ThSa
